4x4 missing on 3-4
Old May 2, 2010 | 05:26 PM
tonytex's Avatar
tonytex
Default 4x4 missing on 3-4
my mates car has a slight mis on 3-4 even on revs and has no power when driven power seems to drop off
changed 1-2 ingeters to 3-4 no change
ht lead's have a spark has anyone had a problem like this
CAN ANY ONE HELP HIM
Old May 2, 2010 | 05:34 PM
JamesH's Avatar
JamesH
Had a similar problem, holed piston
Do a compression test as that will soon tell you the answer. If it is a holed piston and you need to run the engine, then unplug the injector for that cylinder, as you'll just be diluting your oil badly with fuel
Old May 2, 2010 | 05:43 PM
Mark Barber's Avatar
Mark Barber
posss head gasket between 3 and 4 or inlet manifold gasket or vacum pipe off around that area ??
Old May 2, 2010 | 05:56 PM
damian harris's Avatar
damian harris
sideways most if the time
Piston on mine caused this problem..
Old May 2, 2010 | 05:58 PM
tonytex's Avatar
tonytex
getting compression tester tomorrow
Old May 3, 2010 | 02:09 PM
tonytex's Avatar
tonytex
done compression test showing 150 psi in each one
any more thourghts
Old May 3, 2010 | 02:19 PM
rog's Avatar
rog
Check plug gaps & distributor cap, plugs could be knackered also. Suggest you try the cheap things first, if that doesn't work, change the plugs (motorcraft Series 1 RST plugs will do the job, cost around a tenner, that's what most cossie people use).
Old May 3, 2010 | 02:23 PM
rog's Avatar
rog
Spark plugs are Motorcraft 071's, finis code 1120834
Old May 3, 2010 | 06:12 PM
As said do the cheapie/free things first swap plugs and injectors around to see if the problem moves with the swap, this might tell you what it is, then check co when hot.
Old May 3, 2010 | 06:50 PM
martysmartie's Avatar
martysmartie
You say you have checked HT leads but have you checked 3-4 plugs for healthy spark?
Martin
gambo08
Feb 4, 2016 10:49 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
Fil
Sep 30, 2015 12:08 PM
