max boost?
Old Jan 14, 2005 | 11:13 AM
DaveRS's Avatar
DaveRS
Default max boost?
could someone tell me the maximum boost i can run on standard pistons/compression/fuelling? the car is a 1990 S2 with K&N 57i, bailey dump valve, magnex exhaust system.
look forward to hearing from you
DaveRS
Old Jan 14, 2005 | 12:15 PM
turbo.jon's Avatar
turbo.jon
I looked into this mate there are a few that are running over 20 psi but you will need to have bigger intercooler.dont just turn it up as it will blow get it checked over by a tuner..
also is car chiped if not u wont run no more than 10psi or it will cut out...
aint seen you around i only live in gorleston
jon
Old Jan 14, 2005 | 12:31 PM
bassboy's Avatar
bassboy
guys when they say 10psi max boost...is that the peak figure or the held boost? as mine peaks at about 8-9psi and holds about 6psi...maybe 5 lol but i dont trust my gauge as it rests on about 1psi any way lol
thanx
bassboy
Old Jan 14, 2005 | 12:40 PM
GrimmeRS2K's Avatar
GrimmeRS2K
On a standard intercooler, no more than 13-14psi mate, i ran 14 psi on a standard intercooler, still quick, but not efficent, get a pace and u can run a bit more providing its chipped!
Old Jan 14, 2005 | 06:40 PM
AKRS1's Avatar
AKRS1
get it set up right with a uprated intercooler or charge cooler and you see 190-200bhp on 18psi max for standard compression anymore and should see a blown engine not long after
Old Jan 14, 2005 | 06:42 PM
AKRS1's Avatar
AKRS1
by the way when they 10psi on standard ecu thats peak figure should hold 8psi though
Old Jan 15, 2005 | 01:43 PM
RS_JAY's Avatar
RS_JAY
Mine goes up to 18psi, might be a tad more. It holds aswell. Dont like holding it on that though. 15 psi is fine for me.
Old Jan 15, 2005 | 02:52 PM
K18NEO's Avatar
K18NEO
Mines standard, samcos, boost gauge, and a -31... mine boosts at 11psi and holds at 10-9psi... mainly 10.
Old Jan 15, 2005 | 06:31 PM
AKRS1's Avatar
AKRS1
mines is set up to similar figures of rs jay. Im running 2 stage boost 18psi on high boost and 15psi on low boost for town driving
Old Jan 15, 2005 | 10:14 PM
Rallyesport's Avatar
Rallyesport
I'm running 16 psi with standard IC. 22 PSI is no problem with standard compression if the timing is spot on, the fueling is good and a good IC is fitted.
Old Jan 15, 2005 | 11:11 PM
AKRS1's Avatar
AKRS1
16psi with a standard intercooler is probably okay in winter but once it gets a hot in the summer (if we do see summer this year) it'll run very hot. I dont think 22psi would last on standard compression and even if you were running that kind of power you will need a 5th injector or efi management for anything over around 210bhp
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
SMILER258
Sep 28, 2015 09:04 AM
Russ Payne
Sep 25, 2015 08:29 PM
