Standard 4x4 sapphire boast pressure
Old May 1, 2010 | 08:14 PM
mattie170's Avatar
mattie170
Default Standard 4x4 sapphire boast pressure
Hi all,
Just wondering what the standard booast pressure should be, as on my gauge I'm spiking at 0.75-0.8 then it drops to 0.7 then it slowly drops to just below 0.6 by 6k. Does this sound right as I seem to be down on power on the rolling road?
Matt
Old May 1, 2010 | 08:21 PM
bad boy rs's Avatar
bad boy rs
think its about 8psi standard
Old May 1, 2010 | 08:31 PM
mattie170's Avatar
mattie170
I always thought it was 0.7 which is just over 10 psi but I may be wrong. Just trying to find out why I'm down on power.
Old May 1, 2010 | 10:57 PM
opposite lock's Avatar
opposite lock
What power has it made and for a standard setup on your rolling road?
Old May 2, 2010 | 08:46 AM
MARCOSWORTH's Avatar
MARCOSWORTH
0,8 - 0,9 bar on a 4x4
0,7 bar on a 2wd
Old May 2, 2010 | 09:32 AM
mattie170's Avatar
mattie170
It made 189 at the engine on a dyno dynamics rolling road. It has had a new actuator and boost solinoid but still no change. The turbo doesn't smoke and there is no play and freely moves. I think my next move is to change the charge temp sensor as that is meant to drop the boost by 0.2 bar if it is sensing over temp.
Oh and compression is just over 150 psi on all 4 cylinders.
I'm open to any ideas?
Old May 2, 2010 | 11:07 AM
Can you trust the RR ?, emissions from the RR should give a good idea.
Old May 2, 2010 | 11:32 AM
mattie170's Avatar
mattie170
Yes I can trust it and the emissons are good. Is the boost meant to tail off on these ecu?
jason_nike
Aug 18, 2019 10:53 AM
FlashRS
Sep 14, 2015 12:36 PM
Adam-M
Aug 26, 2015 05:53 PM
mrmann
Aug 20, 2015 11:24 PM
Old ford
Jul 31, 2015 06:50 AM
