50mm2 in a st170
help, has knots for several hours and can not find out where I can add the power from the battery into the compartment wall? need someone who has done it before or someone who knows where I can post it?
Sadly it is a difficult one, 90% of people run the cable over the bulkhead and slot it through the panel gap of the passenger wing. Once you thread it through the cable will appear inside the passenger side door shut. You will see a blank grommet in the door shut, cut a slit in the grommet and push the cable through. The cable will then be in the cabin behind the pasenger kick plate in the foot well.
Andypandy260
Sep 23, 2015 10:28 PM
