how much to do a mt75 conversion on a s1
Old Apr 30, 2010 | 04:20 PM
rsmark86's Avatar
rsmark86
Default how much to do a mt75 conversion on a s1
how much is it roughly to do a mt75 conversion on a s1 as this is what everyone thinks is the best conversion.
is there anyone who does it drive in drive out.
what diff .... will my rst one fit
im going to be running around 240/250bhp but am still saving for gt series turbo and brian hansen manifold so need a good box.
Old Apr 30, 2010 | 07:27 PM
jonny s2's Avatar
jonny s2
you should be ok with bc box, mind you its never a bad thing to over engineer things lol
Old May 1, 2010 | 09:00 AM
Kevin_Mc's Avatar
Kevin_Mc
is the ST box a straight fit without cutting the inner wings like you have to with the MTX75?
Old May 1, 2010 | 09:13 AM
rsmark86's Avatar
rsmark86
well its a 2wd mtx75 (sorry guys) well its going to be sort of 250bhp on my turbo but i have plans to buy a brian hanson manifold from jamsport with external waste gate and screamer pipe then looking at a gt28 roller bearing or something of that size ..... but i know what i drive like and after people say that they have broken the cts boxes i know for a fact i would do the same.....
with jano's mtx75 conversion would he fit my lsd in at the same time
Old May 1, 2010 | 10:40 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
sadly an rs turbo diff from either series one or two erst won't fit into the mtx box.
you'd have to get a focus rs diff, which is just a quaife atb diff, about Ł600 on its own.
Old May 1, 2010 | 11:57 AM
morph's Avatar
morph
If your gonna keep the s1 for the rest of your life and never sell it then consider doing the mtx conversion as it will be cutting or grinding back the inner wing of the car. if you ever want to put it back to standard then there will be a bent inner wing or cutout inner wing. the way s1 are going they are becoming alot more expensive and a much rarer car then s2 or fiesta rs turbo's.
or you could get a late big bearing box and have the ib5 gears and bearings fitted which can take upto 250bhp - there a company called GEARS that does such a box.
i have the same recently fitted and it is much better than the standard box.
Old May 1, 2010 | 03:24 PM
muz's Avatar
muz
Wye Valley Hardcore
The thing with the whole cutting your car is trivial. I can see why not for origionality etc but you only have to cut a small section of the inner skin out, not all the way through and if you did a proper job and smoothed it in you would barely recognise it had been done.
Old May 1, 2010 | 09:30 PM
creator's Avatar
creator
Totaly agree with muz here just like muz says if done proply it can be made to lok factory if crazycage sees this perhaps he can put a pic up to show you mate
Old May 1, 2010 | 09:36 PM
jonny s2's Avatar
jonny s2
you can hardly see if done nicely, mine will see the treatment
Old May 2, 2010 | 10:33 PM
rsmark86's Avatar
rsmark86
i realy want it done as because i know i wont stop at 250bhp as ive already got my manifold and turbo choice im saving for .
last time i set a target for mods i said i was getting a big valve head and twin 40s for my mk2 and ended up with a 9k aspirated cosworth on 48s lol .... so i might aswel do the job once.
Old May 3, 2010 | 10:53 AM
Šhatter Box's Avatar
Šhatter Box
just get the later ib5 box from an later escort same gear box holes as your s1 with the stage 2 + its stronger then the bc box. only get an mtx75 if you got more than 300ps of tork imo
Old May 3, 2010 | 11:28 AM
rsmark86's Avatar
rsmark86
its something ive got to look at as mines only gunna last a day with me driving
Old May 3, 2010 | 12:52 PM
12_Second_rst's Avatar
12_Second_rst
I suppose why spend Ł1800 on a cts 2+ when u can spend for an mtx75 which won't break when you get bored and up the power and then there's the choices of better clutchs etc and you know it's not gonna break not that I'm biased or anything lol
Old May 3, 2010 | 01:10 PM
jonny s2's Avatar
jonny s2
ive heard the bearings in the cts boxes need replacing every so often, its worth upgrading to a fit and forget box, other than worrying when its gunna s**t its self every time it sniffs the first sign of serious boost
Old May 3, 2010 | 05:55 PM
rsmark86's Avatar
rsmark86
well thats it as im only on a stage3 t3 at the mo but it will be pumping out around 25psi and then i was either a t34 on my manifold or save up and get a big manifold and gt28 or something like that. so i think i will kill a cts box .
whats the 6 speed st170 box like for ratios ect compaired to the mtx75.....
Old May 3, 2010 | 06:04 PM
jonny s2's Avatar
jonny s2
i believe the mtx box has better ratios than a 170 box but i have been told rs2k boxes are not very smooth in the gear changes
Old May 3, 2010 | 06:18 PM
rsmark86's Avatar
rsmark86
lucky i asked as nearly got a rs2k box yesterday ..... could you tell me what car i would need the box from.
thanks
its a shame as i would love to have mk's old xr2 rolling shell thats for sale in the cars section.... then i could put its old inlet back lol
Old May 3, 2010 | 06:34 PM
jonny s2's Avatar
jonny s2
i think jano uses the rs2k boxes, there a strong box, and can handle the power without too much hacking of the inner wing, but heard there gear changes aint too great
Old May 3, 2010 | 07:15 PM
rsmark86's Avatar
rsmark86
well im not sure realy but i would be using it in anger alot of the time when used so would realy want a quick easy change
Old May 3, 2010 | 07:19 PM
12_Second_rst
Focus rs would be the best mtx as you get the diff free
Old May 3, 2010 | 07:44 PM
jonny s2's Avatar
jonny s2
but they have a rear starter, im sure they could be fitted tho with a bit more work,
Old May 3, 2010 | 07:45 PM
jonny s2's Avatar
jonny s2
someone who have had one done would tell you alot more
Old May 3, 2010 | 07:50 PM
12_Second_rst
I'm sure I've seen one that's had the starter bulge rewelded to the front
Old May 3, 2010 | 08:01 PM
jonny s2's Avatar
jonny s2
i would like to see that as it would be interesting for us cvh boys running more power than the box could take
Old May 3, 2010 | 11:10 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
you could get a mondeo mtx front starter box from a tdci and remove the bellhousing, then mount bellhousing onto the focus gearbox.
job done, front starter with cable shift and hydraulic clutch.
the rs2k boxes need mods to selectors etc, best just to change over to a cable shift etc. if you're going to do the work.
Old May 4, 2010 | 08:22 AM
rsmark86's Avatar
rsmark86
i think im going to just get my money out for a conversion as i dont realy get the time to it anymore so will just pay somemone.
Old May 4, 2010 | 08:30 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
So all this talk, on here say!
Have you even tried changing gear with an RS2k and MTX75 gearbox. If not how can you comment on how well it changes gear or not. ??
Go compare an RST gearchange with an RS2k gearchange then tell us all how it feels for real not just guessing!
The MTX75 Gearbox has a much better gear change and linkage than any of the RS's FWD. Fact!
Do some decent research for youself then comment on how good or bad something is. Dont take others point of view and experiance as gospel.
Old May 4, 2010 | 08:35 AM
rsmark86's Avatar
rsmark86
well good point as my standard linkage is like a sausage in a alley way lol ... but this is the conversion im going for as i dont want to spend big money on a bc box and blow it to bits.
Old May 4, 2010 | 07:44 PM
Rick's Avatar
Rick
The rod change MTX is well documented in the press for having an unpleasant gear change. That's why it was changed to cable shift for later models.
Rick
Old May 4, 2010 | 10:26 PM
DazC's Avatar
DazC
The tdci box doesn't have provision for a starter at all nevermind a front starter! Bolts to the engine on the tdci.
Old May 5, 2010 | 06:08 AM
jonny s2's Avatar
jonny s2
read my posts properly what i have said, im by no means having a dig at the conversion or the gearbox in question,
Old May 6, 2010 | 11:10 AM
Versus_Creations
Ask me a question!
Rick
The press has no comparison with us.
Some random person from a mag in 1990's gets in to an RS2k and comments about how it feels compared to other cars of the same era.
Get the same person to feel a random S2's linkage (if it has a useable one on it, as most are fukd) then ask them to compare to an RS2k.
That would be a good comparison.
Old May 6, 2010 | 11:27 AM
1223456's Avatar
1223456
Ive driven rst's with standard boxes, and with quick shift shifters, had a spin in crazycages fiesta which has the focus rs cable linkage box, it is starting to show signs of wear which I couldnt notice, the feel of it was unreal so smooth and precise with very little travel between gears. Dont know what the 170 box is like but you can take it from the focus rs box is one hell of a good mod to consider.
Hope this helps
Raj
Old May 6, 2010 | 12:11 PM
crazycage's Avatar
crazycage
[/QUOTE] really! Have you for got about the focus rs?
Old May 6, 2010 | 12:21 PM
rsmark86's Avatar
rsmark86
thanks guys well its on the shopping list now
Old May 6, 2010 | 12:29 PM
12_Second_rst
crazy is just saying that the focus cable shift is much better than the rs2k rod shift
and tbh i agree
Old May 6, 2010 | 01:30 PM
crazycage's Avatar
crazycage
Isn't the focus a MTX75 anyway Or we talking the new MK2 [/QUOTE]
yes the mk1 focus rs box is a mtx75! but its nothing like the 20 year old rs2k box.
