t38 turbo
Old Apr 30, 2010 | 06:54 AM
davecosworth's Avatar
davecosworth
IM BACK
Default t38 turbo
ok just done a bit more digging around and it turns out its not a t38 its a escort cosworth stage 1 hybrid s115 t35/.55 good for 400bhp so need a rebuild on the above unit not a t38. new seals and bearing any one no if i can have it machined to fit a roller bearing put in it or best off with just 360 degree race spec bearing. last month it was clutch so went a bit made rebuilt the diff gearbox new flywheel and diff mounting now turbo just when i though i was getting on top of it o well
Old Apr 30, 2010 | 11:40 PM
Karl 3dr's Avatar
Karl 3dr
Best people to speak to are C.R turbos mate, ask for Vince, top fella!!
Old May 1, 2010 | 05:51 AM
BRAMMER's Avatar
BRAMMER
Don't forge if your changing turbo spec you need a new chip to suit, didn't think a 55 would go that far???
Old May 1, 2010 | 12:05 PM
martysmartie's Avatar
martysmartie
Second CR Turbos and as said about the chip as the exhaust housing is critical to the software. Not sure if you could squeeze 400HP without pushing it very hard more like a true 380HP I should think, know with a .63 400HP+ is possible.
Martin
Old May 1, 2010 | 05:48 PM
Will do 400 all day long, a .48 will do at least 380.
Old May 2, 2010 | 05:28 PM
davecosworth
IM BACK
would like to change the .55 to .63 housing really just been looking for one but they are stupid money on ebay was thinking of putting one on when its getting rebuilt at work also would like to use a air injector any one no whats involved got to put it back on the rolllers after as the turbo was stalling due to bearing going on turbo
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
