Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
ford galaxy keeps cutting out whilst driving help please
Old Apr 28, 2010 | 09:03 AM
stukim's Avatar
stukim
Default ford galaxy keeps cutting out whilst driving help please
hiya can anyone help i have a ford galaxy 2.0 litre petrol n-reg whilst driving the car just shuts down. i have to leave it a couple of minutes then it will start up again ive changed the map sensor, the maf sensor and crank shaft sensor really need some help please thanks kim
Old May 3, 2010 | 02:55 PM
duderacing's Avatar
duderacing
My parents had a galaxy a few years back. It was a tdi, but the same issue they had may have affected your's. Check for damp unerneath the front passenger seat, as that was where a lot of the electonic control modules were housed. Theirs was pretty much flooded, and caused some major running problems.
It's a long shot, but as nobody else seams to be able to help, thought I'd try.
Old May 4, 2011 | 11:07 AM
leonie's Avatar
leonie
mine is an s reg and is doing the same but it as also started to be very slugish , took it to 2 garages and none can find a fault , in the mean time cant go anywere in case not start again and is costing a fortune to keep having it looked at shell
Old May 4, 2011 | 02:09 PM
isaac james sherwood's Avatar
area six 2.1 zvh ford ka
Default engine management relay
relay no 109 is faulty change it and it will be fine
Old May 4, 2011 | 09:20 PM
leonie's Avatar
leonie
thank u i will try that and let u know .
Old Jun 26, 2011 | 09:09 PM
shazanjase's Avatar
shazanjase
Did replacing the relay 109 work? I have the same issue
Old Jul 4, 2011 | 09:32 PM
leonie's Avatar
leonie
Default relay 30
no it didnt but i did fix it , if u go on the ford galaxy owners club site and put in relay 30 replacement , it gives u full details on how to replace it relay 30 that is , it is a bugger to get to but it is really well detailed and the bloke as added photos aswell . the relay cost me £22 and it took a couple of hours to do , but my car is working brilliently and had no probs since . let me know if its helped
Old Aug 12, 2016 | 09:17 AM
Tonisalt's Avatar
Tonisalt
Default Car cut out
Hi I had a new engine mount fitted last week and travelled up north and the car has cut out 3 times whilst driving.
Old Sep 20, 2018 | 07:03 PM
Johncarhead's Avatar
Johncarhead
Default Hi
Hi guys have a Ford galxay 2007 model diesel 2 liter cutting out problem after driving for a couple off times say 1 hour it cutts out and have to wait for start up say 15 muintes or more any ideas
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Bailes1992
Aug 16, 2015 07:14 PM
englandbrad
18
Aug 6, 2015 09:24 PM
