Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
Mondeo 4x4
Old Apr 25, 2010 | 08:56 PM
Brettski mk2's Avatar
Brettski mk2
Default Mondeo 4x4
Hi
A friend has got a Mondeo 4x4 2.0 zetec?? that he wants me to look at
It has a problem
It starts fine and runs fine until it gets to working temp then has a misfire.He said he's changed the leads/plugs.
I will get the car to mine in the week to look at but thought I'd ask on here to see if it is a common thing?
Thanks Brett
Old Apr 25, 2010 | 09:06 PM
xr2 turbo lhd's Avatar
xr2 turbo lhd
Too many LHD fords
Originally Posted by Brettski mk2
Hi
It has a problem
Thanks Brett
early zetec's suffered with sticky valves when hot especially when run with the wrong oil or if it hasn't been changed for a while.or check coilpack isnt breaking down when hot. hope this helps
Old Apr 26, 2010 | 03:59 PM
As above would be worth bunging in some wynns hydraulic valve lifter lube, £8 from halfords, recently used on a mondeo, frontera, rover v8, and cossie(yb) all had very noticeable improvements after using.
Old Apr 26, 2010 | 06:53 PM
Brettski mk2
Cheers for the heads up on this
wowk
Mar 30, 2021 07:49 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Iain Mac
Sep 30, 2015 09:39 PM
The Enigma
Sep 29, 2015 10:31 AM
