Boost controllers
Old Apr 25, 2010 | 06:34 PM
mr_joe0606's Avatar
mr_joe0606
Default Boost controllers
Hi guys just wondering how electronic boost controllers work??
CheeRs joe
Old Apr 25, 2010 | 06:50 PM
Karlos G's Avatar
Karlos G
Balls Deep!
They are just like a bleed valve mate, but instead of you opening or closing the valve to bleed off more or less air, it's done by a solenoid which is controlled by the controller in the car.
Some have a MAP input so they are active, and others do not and simply bleed what you set them to.
Old Apr 25, 2010 | 07:02 PM
mr_joe0606's Avatar
mr_joe0606
I have just fitted a new actuator and just wondering which way to turn it to ajust the boost becuse I should be boosting to 15 psi but it's goin up to 19 which way do I turn it? Do I screw it out make the rod longer or screw it in making the rod shorter.
Cheers joe
Old Apr 25, 2010 | 07:05 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Longer mate for less boost, about 2.5 turns should get you close to where you want.
Old Apr 25, 2010 | 07:09 PM
mr_joe0606's Avatar
mr_joe0606
Cheers pal! When I was putting it on it was tight lol thanks for the info cheers
Old Apr 27, 2010 | 07:42 PM
Rick's Avatar
Rick
They work more like air injectors than a bleed valve
Old Apr 29, 2010 | 04:46 PM
Stu @ M Developments's Avatar
PassionFords Creator
I wrote an article on such things once, it should be somewhere in here:
Old Apr 29, 2010 | 05:02 PM
RSargie's Avatar
RSargie
but off topic but, now your in the rs turbo room stu could you take a look a post i did on ecu voltages in here i wiil fing it and bump it to the top thanks.
Old Apr 29, 2010 | 05:31 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Not sure I agree with that really Rick, all EBC's i've seen employ a 3 port solenoid just like our Amal valves, or a bleed valve, air injectors are just that... injectors not solenoids
Although you have a similair level of control with a good EBC (AVC-R for example) as you do with AI.
Old Apr 29, 2010 | 05:48 PM
Rick's Avatar
Rick
Yes, but how do they bleed?
Old Apr 29, 2010 | 05:54 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Solenoid opens the valve to atmosphere, injectors directly control the presure that gets to the actuator rather than whats bled off.
Old Apr 29, 2010 | 06:13 PM
Rick's Avatar
Rick
No, the boost controller has the wastegate normally connected to atmosphere. When the boost reaches the set point, it switches the valve so that the wastegate is now connected to the intake rather than atmosphere so the gate opens.
It is a bleed on system, the wastegate doesn't see any pressure until the controller says so. This is the same as an air injector which when closed doesn't present any pressure to the actuator.
A bleed valve simply continuously diverts some of the pressure away from the actuator, as soon as there is boost there is pressure supplied to the actuator.
Rick
Old Apr 29, 2010 | 06:31 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah I see your point.... it's a cross between the two as AI doesnt bleed to atmosphere at all.
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
