water temp sender position..
as above really..got the run about MOTed etc till i get cossie back and seems we have no temp gauge..
think ill just drop a water temp gauge in a pod somewhere as it has been know to overheat...dam fan wiring...sorting that out also!!..
can anyone point out where it is on engine.. is it the one as you look from front of car ...right hand side just above turbo and by water sensor for fans... someone told me thats the oil one..
also is it a standard 1/8npt?? if it is can just wind the new aftermarket one in there for pod... thnx in advance..
Mark RS
Oct 12, 2015 06:01 AM
