gti escort
Old Apr 18, 2010 | 09:57 PM
hawkeye37's Avatar
hawkeye37
Default gti escort
hi i have a 97 escort gti the problem i have is the idle will not come down below 1200 revs i have put a new idle valve on changed the maf sensor and been told to change a small pipe at the bottom of the inlet manafold as it was very soft has any one got any ideas please
Old Apr 18, 2010 | 10:03 PM
focusv8's Avatar
focusv8
Have you set up the throttle position sensor (if it has one)?
Have you set the idle with the Idle valve unplugged?
Have you reset the ECU?
Old Apr 18, 2010 | 10:43 PM
phil_focus's Avatar
phil_focus
as far as i'm aware you cant manually set anything on these engines as its all controlled by the ecu.
hawkeye, definately replace that vacuum hose as they collapse and cause a high idle. that hose is actually part of the crank case breather system and if you trace it forward you get to a 90 degree corner that goes onto the pcv valve located on top of the oil seperator on the front of the block. its worth replacing this valve (think Ł12 from ford) aswell as it can cause a high eratic idle too.
i replaced those and the idle control valve on my 1.6 mk6 escort when i had it and she ran like a dream after that. might be worth an ecu reset and a service too depending on when it was last serviced.
Old Apr 19, 2010 | 06:19 PM
rs_traynor's Avatar
rs_traynor
stage4 2wd cosworth
maybe a leak from the inlet gasket.
Old Apr 19, 2010 | 06:21 PM
hawkeye37's Avatar
hawkeye37
thanks u all will try every thing
Old Apr 19, 2010 | 06:28 PM
BM08's Avatar
BM08
When i had this issue with my GTi a few years ago it turned out to be the throttle position sensor, it was as good as new after replacing it
Old Apr 19, 2010 | 06:48 PM
RichieST's Avatar
RichieST
Could be a inlet manifold gasket failed or even inlet manifold cracked. Have a squirt around the gasket area with easy start and see if the rpm's fluctuate at all.
Old Apr 19, 2010 | 07:16 PM
hawkeye37's Avatar
hawkeye37
hi do u know how to set the idle with the idle unpluged
Old Apr 23, 2010 | 06:37 PM
hawkeye37's Avatar
hawkeye37
thanks everyone but it turned out to b the new idle control valve faulty
Old Apr 23, 2010 | 11:29 PM
phil_focus's Avatar
phil_focus
ah, glad you go i sorted....can be really difficult to find these faults when the parts suplied are faulty!!!
Old Apr 25, 2010 | 09:07 PM
hawkeye37's Avatar
hawkeye37
Smile
thanks phil was up oulton park sat modified live there where some nice motors there
Dr. Ickxs
Sep 15, 2015 10:15 PM
rogerxr3i
Sep 13, 2015 06:56 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
