How much oil does you escos use/burn?
Old Apr 18, 2010 | 04:05 PM
liamford's Avatar
liamford
Default How much oil does you escos use/burn?
hi guys, my cossie seems to use quite a bit of oil, when i shut off, let it run in gear, then put my foot back down i get a puff of smoke now and again, i have changed the turbo but think it needs reconditioning now because there is a bit of play in it, but other than the turbo going... how much oil does your cossies use? / miles.. cheers liam
Old Apr 18, 2010 | 04:11 PM
martysmartie's Avatar
martysmartie
A little bit is nothing to worry about, when new Ford said 1 litre to 600 miles is normal.
Martin
Old Apr 18, 2010 | 07:50 PM
j6kyt's Avatar
j6kyt
mine dont burn much just leaks it. lol
Old Apr 25, 2010 | 10:51 AM
stookay's Avatar
stookay
mines leaks oil from front crankshaft seal , ive replaced it 3 times , ive given up now,
i think tabetha said there was a different kind of seal that can be fitted.
if i had the undertray it wouldnt leave a pool on garage floor.
Old Apr 25, 2010 | 11:07 AM
RS500/364's Avatar
RS500/364
Maybe you should get the cover skimmed to sit flush !
Old May 4, 2010 | 06:32 PM
ASHCOSSIE's Avatar
ASHCOSSIE
mines used a about half litre in 3000 miles
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
