T34 Overhaul
Old Apr 16, 2010 | 04:34 AM
wilmot's Avatar
wilmot
Default T34 Overhaul
Does anyone have any idea roughly how much it costs to have a T34 over hauled ... its partially seized, still turns, but has play in the shaft... Only want peoples opinion whether I buy a new one or have mine over hauled.... I also have a T38 I bought from Flea Bay., the Turbo itself is perfect except some clown has welded up the Lambda senor hole on the top.... Anyone any ideas where I can get this sorted out.. Thanks to all that can be bothered replying constructively ....
Old Apr 16, 2010 | 11:55 AM
R4N SS's Avatar
R4N SS
t34 rebuilds are roughly between 200-500 depending upon the amount of damage you have done.
first time my t34 was rebuilt it cost around 2-250 and the last time it was rebuilt was around 500 - and it got rebuilt plenty of times inbetween.
I was running the turbo was on its knees hence why it needed a rebuild 12-18 months
Oh and with regards to the welds for the lambda - can you not drill through this and weld in your own boss?
Old Apr 16, 2010 | 07:51 PM
wilmot's Avatar
wilmot
Thanks alot for your reply, will dig out Turbo Technics address tonight and get it posted to them and will have a go at this welded bolt tomorrow at work...
Old Apr 16, 2010 | 07:56 PM
wilmot's Avatar
wilmot
Thanks for your advice, will get my Turbo off to Turbo technics in the next couple of days.... and will have a go at the welded bolt tommorrow morn in work.. Thanks again, Noel
Cosnada
Jan 7, 2016 05:30 PM
Russ Payne
Sep 25, 2015 08:29 PM
locum8
Sep 14, 2015 08:45 PM
