Speedo not working
Old Apr 15, 2010 | 11:00 PM
muz's Avatar
muz
Wye Valley Hardcore
Default Speedo not working
The speedo on the XR3 isn't working. I've tried 2 sets of dials and put a new cable on but it still reads 0. Doesn't even wobble. Is there a chance the drive in the gearbox has gone? I've never heard of this happening before?
Old Apr 16, 2010 | 08:45 AM
mr_joe0606's Avatar
mr_joe0606
Sorry to hijack but my spedo is out about 8 mph so wen doin 30 the clock says 22 can you ajust it??
Joe
Old Apr 16, 2010 | 08:53 AM
Mk1 Mex's Avatar
Mk1 Mex
Series One
Hi,
I've now got the same problem, its the gearbox end that might be your prob.
If you can disconnect the cable from the gearbox and get someone to sit in the car to watch the speedo. If you spin the cable at the gearbox end the needle should move slightly, if so you need to replace the (god cant remember the part name) part in the gearbox that feeds the speedo.
Hope this helps.
Old Apr 16, 2010 | 10:09 AM
muz's Avatar
muz
Wye Valley Hardcore
I can see it would be the drive in the gearbox. Would explain why the chap was so helpful to offer to deliver the car if I bought it. He must have known it didn't work
Old Apr 16, 2010 | 12:32 PM
Micky's Avatar
Micky
Speedo drive worn in the gearbox is a sign that the diff bearing are worn out.Micky
Old Apr 16, 2010 | 12:38 PM
martysmartie's Avatar
martysmartie
Joe
What tyre size do you have? If it's RST in siggy I see that has 17" + on it.
Martin
Old Apr 16, 2010 | 01:04 PM
muz's Avatar
muz
Wye Valley Hardcore
Cheers Micky. Drive it till it dies then!
Old Apr 16, 2010 | 02:54 PM
mr_joe0606's Avatar
mr_joe0606
Martin
Yeah they are 17s I don't think it will be the wheels making it that far out mate. And should bigger wheel make the spedo go faster than you actually are??
Old Apr 17, 2010 | 04:06 PM
martysmartie
No as you say not by that much, could be the speedo out of calibration or if it's always been like it someone has fitted an incorrect one? On the face look for a number this is the TPM number, assume you still have standard box as well?
Martin
Old Apr 17, 2010 | 11:46 PM
Big-Dan's Avatar
Big-Dan
Joe
Does it sit level on zero when not in use?
If it is sitting below zero just push it back round, if not I imagine you will need it re-calibrating?
Big-Dan.
Old Apr 18, 2010 | 08:43 AM
ROB7656's Avatar
ROB7656
drive worm is dead . not always meaning a dead diff/box.
Tinshaw
Aug 4, 2015 09:16 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
jimmy oldskool
Aug 4, 2015 07:06 AM
Escortdriver1
Jul 31, 2015 02:36 PM
