Aeromotive big hp fuel pump and rs500 fuel rail for sale
Old Apr 15, 2010 | 07:43 AM
saphycozzie-adz's Avatar
saphycozzie-adz
Default Aeromotive big hp fuel pump and rs500 fuel rail for sale
As in title. Originally supplied and fitted by Reyland motorsport. Now no longer required due to a change of plans for our Escos. The car was speced out for 600bhp but now we are staying with 400 so we now only need the 044 item. It is supplied along with the aeroquip fittings which are -10 and -8. It was on the car for about 2 years but in that time only did about 2000 miles max. I believe this is the same type of pump used on the Reyland Escos so it is a very capable unit.
They are £350 inc vat from Reyland without the fittings.
Only £240 delivered within the Uk.
Cheers.
Adam.
07968545399 or saphycozzie@hotmail.com
Old Apr 15, 2010 | 08:02 AM
saphycozzie-adz
Default Rare mint Rs500 top fuel rail for sale.
AS IN TITLE. CANT BE TOO MANY OF THESE AVAILABLE NOWADAYS. ITS IN EXTREMLY GOOD CONDITION WITH A -6 FUEL INPUT TO FIT STRAIGHT TO AN AEROQUIP FUEL LINE. THIS IS NOT THE SAME AS A NORMAL FUEL RAIL AS IT HAS THE OUTPUT FITTING TO SUPPLY A SECOND RAIL AS FITTED ON ALL FACTORY RS500'S. THE FUEL FEED TO THE LOWER FUEL RAIL IS STILL BLANKED OFF SO THIS CAN BE USED AS A SINGLE RAIL IF NEEDED
£100 POSTED WITHIN THE UK
Old Apr 15, 2010 | 12:48 PM
rog's Avatar
rog
Where does this attach to, onto the plenum/inlet cover? I presume it won't fit a 4x4 saph????
Old Apr 16, 2010 | 09:03 AM
saphycozzie-adz
I don't think it does fit 4x4 mate no.
Old May 7, 2010 | 02:57 PM
saphycozzie-adz
BTTT
wheelwizardrefurbs
Aug 29, 2015 09:25 AM
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Harris.
12
Aug 12, 2015 06:38 AM
dlwarrior
Aug 5, 2015 10:19 AM
