how to uprate the standard cossie 2wd diff
anyone any imformation on it , like is it worth doing or would i be better off buying a proper plate type lsd and if so wheres the best place to get one , my sierra is very unpredictable wen drifting etc , any advice greatly appreciated thanks
Trouble now with the standard diff is the visous coupling normally needs a re rate this is what causes alot of the trouble also the planet gears are weak, they can cope with moderate power quite well but if your doing alot of hard lauches they don't last long. You can get plated diffs they are a good upgrade and go in place of the standard with no additional fabrication.
Martin
Martin
Particularly pages 2 and 3 for info on the viscous coupling
https://passionford.com/forum/genera...-cosworth.html
Also this is interesting
https://passionford.com/forum/genera...nions-pls.html
With regard to viscous coupling diffs, as far as I know CTS and Bara will both restore/uprate a VC type diff. I'd suggest you need access to specialist equipment/viscous fluids to do it yourself. Depending on where you live in the country take it along to one of those guys to get it done.
Obviously you've still got the problem of the OE gears.
Unless you can buy bits secondhand and/or fit/machine bits yourself or at mates rates it will be a four figure sum for a plated/Quaife diff up and running
Oct 9, 2015 07:38 PM
rog
Sep 4, 2015 12:10 PM
FlashRS
13
Aug 31, 2015 06:02 PM
