Cossie handbrake
Old Apr 14, 2010 | 01:33 PM
cameron2's Avatar
cameron2
Default Cossie handbrake
How do you disconnect the cable from the rear caliper?
Old Apr 14, 2010 | 01:40 PM
xr4x4rs's Avatar
xr4x4rs
remove the small clip from where it goes into the main body of the caliper, then on the hook thing where it attaches theres an oval slot, use a decent flat blade screwdriver and twist the hook back to give you slack to remove it
make sure you undo the tension first from the adjusters aswell
Old Apr 14, 2010 | 06:47 PM
cossiegreg1's Avatar
cossiegreg1
its a bastard. i did similar as above, used some grips on spring then pryd the cable off with screwdriver
good luck
Old Apr 14, 2010 | 07:03 PM
cameron2's Avatar
cameron2
good luck
Had a pop at it earlier and thought it was a bastard! Didnt succeed, thats why im here!
Will attack again at the weekend!
Old Apr 14, 2010 | 07:16 PM
avinit1rs's Avatar
avinit1rs
AV IT!!!
I un-wound the adjuster from the underside of the centre of the car and then they just came out of the caliper. was pretty easy to do, didnt take long.
Old Apr 14, 2010 | 07:17 PM
cossiegreg1
its easier with a extra set of hands,
the will be a easy way but i havnt found it!!!
Old Apr 14, 2010 | 07:19 PM
focus 4x4's Avatar
focus 4x4
Spot on .
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
