mk1 sierra stereo adaptor
Old Apr 13, 2010 | 10:08 PM
sierraswash's Avatar
sierraswash
Default mk1 sierra stereo adaptor
Hi. I am trying to locate a stereo adaptor for my mk1 cossie so i can fit a different stereo. I have the std Ford stereo in at the mo. When you take it out it has like an 8-pin Din plug and a rectangle connector. All the adaptors you can buy wont fit this.
Does anyone know where i can get one from.
Thanks.
Old Apr 13, 2010 | 10:15 PM
botters's Avatar
botters
competant bodger
i would wire the stereo diresct to the original wiring on the car you dont have to cut the plugs off to do so just trim the insulation back and solder the new stereos wiring on then re insulate
Old Apr 13, 2010 | 10:19 PM
sierraswash
Yeah i suppose thats a way. Feel happier if i could get a proper adapter though. Rather not do that if i can help it.
Old Apr 14, 2010 | 08:39 AM
R4N SS's Avatar
R4N SS
go to halfrauds and buy an iso adapter and wire that to your stereo
or
as stated wire it direct into your existing loom.
its a stereo - its not exactly the hardest thing in the world to sort.
Old Apr 14, 2010 | 02:50 PM
Jaz's Avatar
Jaz
Halfords mate for an plug and play sterio loom with the correct connectors either end,no cut and shut needed!!!
Old Apr 14, 2010 | 03:26 PM
sierraswash
Yeah i looked at those plugs but wont fit my stereo wiring. I have a DIN plug on the back and not just 2 block connectors so those wont fit.
Old Apr 14, 2010 | 07:28 PM
Jaz's Avatar
Jaz
U did say din plug!!!!
Ok if im right u may have a factory amp fitted. Usually in sum of the older fords they were above the pax kick panel behind dash/left of glovebox area.
I bypassed one in an car i once owned, if i remember right the other plug that u are missing is plugged into this amp(these will be the speaker output wires btw). You can still use the halford iso connector wiring but youll have to extend the wires to reach the amp(no need to cut original wiring)???
If no joy mate ignore what i said before its cut n shut time!!!
Hope this helps.
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
nico12
Dec 31, 2015 04:42 PM
S3an
Sep 26, 2015 11:39 PM
S3an
13
Sep 13, 2015 10:01 AM
