Trapped air in hot water system?
Old Apr 12, 2010 | 05:34 PM
RichieST's Avatar
RichieST
Default Trapped air in hot water system?
Hi all
When the boiler is on heating the hot water tank, every few minutes I can hear what sounds like air bubbles rushing through the pipes. Only seems to have recently started doing it, can't recall it doing it before. Is this normal? If not is there a bleed valve or something I can open? Its a gravity fed system.
Doesn't do it when the central heating is on as far as I'm aware!
Rich
Old Apr 12, 2010 | 05:45 PM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
Do you have any water coming out of any overflows outside?
Old Apr 12, 2010 | 05:50 PM
RichieST's Avatar
RichieST
No there isn't mate.
Old Apr 12, 2010 | 05:57 PM
Steve the Plumber
Have you had any works done to the mains or to the heating system recently?
When you draw hw from any hw tap, does the hw splatter about coming out of a hw tap?
Old Apr 12, 2010 | 06:31 PM
fraser9764's Avatar
fraser9764
ours was making some funny noises like this the other night, not noticed it since though.
Old Apr 12, 2010 | 06:40 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
Sure you don't have the stat up to high and its boiling out the vent pipe.
Steve
Old Apr 12, 2010 | 06:52 PM
It's Czech Mate's Avatar
It's Czech Mate
yes and yes for me
Old Apr 12, 2010 | 07:04 PM
Steve the Plumber
Czech Mate, Sounds like a pipework problem, sucking air in causing spluttering,
Rich 170, Whats the cylinder stat set to on the hw cylinder?
Old Apr 12, 2010 | 07:05 PM
rubinsbin's Avatar
rubinsbin
bleed it-----------go get a swirl pot.
Old Apr 12, 2010 | 07:06 PM
rubinsbin's Avatar
rubinsbin
akin to banging pipes in a domestic heating system-------air in system/bleed
Old Apr 12, 2010 | 09:12 PM
RichieST's Avatar
RichieST
Heating system is a Honeywell Smartfit, its an all in one digital timeswitch/thermostat etc. The water is set to 60 degrees.
The hot water system was drained down about a month ago when I had the shower taken off, re-tiled and refitted. Not too sure if it was making the noise before then or not though. The hot water runs fine though, no splutters, and plenty of flow. Only thing I would say is that I've got a thermostatic mixer shower, and since it was refitted, you seem to have to have the dial thing set more towards cold than it was before?
Rich
Johnny Knoxville
Sep 30, 2015 07:21 AM
Russ Payne
Sep 25, 2015 08:29 PM
Brickhouse
Sep 21, 2015 11:00 AM
coscor86
Sep 20, 2015 01:21 PM
