Anyone else had this problem with there xbox?
take it you mean the disc is brand new and therefore not scratched??
if so and it can read other discs then this one is corrupt and you should take the game back with that pic and get them to exchange it.
Never gonna give you up!
You could also try this:
Solution 3: Clear your system cache (game discs only)
If your Xbox 360 console can't play multiple game discs, try clearing your system cache. Here's how:
1. On the console, go to My Xbox, and then select System Settings.
2. Select Memory.
3. Highlight any storage device, and then press Y on your controller.
4. Select Clear System Cache.
Collapse this imageExpand this image
Note If Clear System Cache is not available, use the button sequence described in the following article:
971755 (http://support.microsoft.com/kb/971755/ ) How to clear the Xbox 360 console cache
5. Try to play a game disc.
2. Select Memory.
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
