M14 internally threaded tube
Im after a section of tube pre-drilled and tapped for M14, does anyone know of anywhere I can get it off the shelf as its something I need in a hurry so no time to get it made specially really.
Basically like this:
http://cgi.ebay.co.uk/M14-Right-Hand...item58814fbf40
But needs to be 6 inches long (or 2 * 3" would be fine)
Yes thats exactly what my "contingency plan" is at the moment mate, but it would be neater if I could just get a single piece, its for a steering component and they tend not to like welding visible on them.
try your local hydraulic or fastner place
there's a few places in swindon that will do it but i guess it depends on how desperate you are for it
I have used these connectors in the past
http://uk.rs-online.com/web/search/s...duct&R=0276566
RS dont list an m14 version but no doubt other fastener suppliers would stock them
do mcgills not sell it?
edit: Nope just looked. could you not use a threaded insert inside a tube? does it really need to be threaded all the way down? Would look neater and be stronger than the welded together method.
