zinc plating question
been stripping my engine bay down today for cleaning thinking of having all the rusty nuts and bolts cleaned and plated
what happens to nylock nuts when u have things plated tho?
I done abit of research when i was looking for a decent plater, and sure i read nylocks are fine, sure ive also seen resto threads with re plated nylocs on the Escos forum. Get in contact with Chris Latham on RSOC site, he does zinc plating to an awsome standard and also does the prep work.
If the nylocs are at the point of needed replating then you really shouldn't be re-using them as the nylon simply wont be effective anymore. Just buy new ones - it must be more cost effective than getting a small batch of stuff plated anyway? Try Kenton Fasteners - http://www.applegate.co.uk/all-indus...le-1177367.htm - good guys and stock most stuff in a1/a2 stainless, BZP, chemically blackened, etc
Chris
Chris
If i was replacing the fixings on my car i would use grade A2 stainless fasteners. Grade A4 is also available but they are a lot more expensive.
Might be worth others giving their experiences of using stainless fasteners on cars as my fasteners at work are only used on machines used in research laboratories (nice clean & dry environment). Maybe the stainless properties break down in certain applications on cars due to heat or vibration (but i doubt it).
There will be some places on a car where stainless will not be suitable due to the high torque settings required.
when i did my engine bay, i replaced all my bolt where possible to grade a2 stainless steel ones. The high stress areas tho you cant change, so best to get plated.
I dont like plating much tho, as if you end up scrathing it, it will rust again.
nothing wrong with using stainless steel bolts tho.
Only trouble is you will find it hard to buy only a few, most bolts, nuts etc come in boxes of 100. so it could end up costly. I way lucky as we use stainless ones at work.
the nylocks will be fine, the plastic just changes colour, dont have high tensile bolts done
ive even had this zinc plated again and hasnt affected the rubber one bit or plastic, if anything its cleaned them
so on my 1983 sierra, when i removed the rear shock bolts to fit the coilovers, how come i could do the nyloc nut back up with my fingers, even through the nylon part that is supposed to cause friction on the bolt so as not to vibrate off?
no point in sand blastig them, just soak all the rusty bolts in vinegar for a few days, this will clean all the rust on them, then put them have them zinc coated and will be like new again
but if you leave them out of the vinegar for a few days they will go rusty so best bet is clean them up and when your ready to take them to the coaters just give them a quick wipe and get them sent off
Most platers will have a minimum plating charge so get it all of your parts done in one go if possible not a handful here and and a handful there. Also when we get plating done at work, if we want a bright finish we don't shotblast the component but if we want a dull finish we do shotblast it.
Finally if you do go down the stainless route by your fasteners from a proper dedicated fasteners supplier as you will get the best prices and if you pay cash they shouldn't bother with minimum orders. Most of the smaller sizes (M4, M5, M6) they will prefer to sell in bags/boxes of 100 but biggers sizes (M8, M10, M12) they will sell in smaller quantities such as tens.
If you are in the Northants/Bedfordshire area i can recommend Anglian Fasteners Ltd, i have used them for about 15 years and find them to be a good company to deal with.
At a guess the nylon being so old has dried out and gone brittle?, either way nylocs are designed and can be used many times over.
As you say, re-use is a different issue to ageing - replating is being done because the bolts are old, so it is likely that the nylon has dried too. In any case, the plating on a new part is likely to be superior to that of a re-finished one, and there would be no need to measure the locking torque of the nut to make sure the nylon hasn't failed, only to find that it has and that you wasted the money getting stuff plated......
Chris
Chris
if your going zinc it'll just rust... your better of galv or stainless.
i dont do plating but i sell zinc plated nuts/bolts/washers anything really.. even galv stainless , self colour (black) even delta at a push
chowfornow
14
Jan 5, 2019 09:01 PM
DavidK
Sep 27, 2015 02:55 PM
