Escort gerbox mounts
Can anyone tell me if this is the right gearbox mount....
The metal bit.
Basically, with these mounts the the whole engine/box is too far over towards the drivers side and I can't figure out what the fuck is wrong.
The thing that makes me think it's the mounts is that bolt hole in the top of the mount that I don't think is used for anything.
The metal bit.
Karlos any chance of a pic so i can see the difference between the two.
Botters, cheers. I've been told this brace might be missing.
What is doing my head in is that with my gearbox mounted like my picture means that the top engine mount is about 10mm out. Almost like the engine/box are too far over towards the drivers side.
i can get a picture of the mount on mine later if you like?
Original mount from xr3i but bolted to IB5 which is pretty much identical.
I'll post pic later this afternoon.
