Rev Counter 1000RPM out
Gents,
I took out the clocks on my 3 door to change the bulbs. When I put it all back the rev counter now rests well below 0 RPM! The rev counter now works, but reads approx 1000 RPM lower than it should.
Does anyone know how to sort this problem?
Thanks in advance.
Thanks in advance.
you must resolder your tachometer. take out your rev counter and resolder all connections on its circuit board. there is cold solder joints. and then you must recalibrate your tach from adjustment potentiometer, on the circuit board. use external rev counter for calibrating your original rev counter.
TPM961
Jan 15, 2018 10:50 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
cozzy jeff
Aug 14, 2015 05:46 PM
