BMW 320d M sport
Old Apr 10, 2010 | 07:25 PM
kiddie's Avatar
kiddie
Default BMW 320d M sport
Looking at one of these tomorrow, it's on an 04. Now what I've read these suffer from turbo problems, but it was only on the pre 2003?
Apart from that are they fairly reliable?
Old Apr 10, 2010 | 07:57 PM
Danny @ Enhanced Performance's Avatar
my mates got a nice 04 plate touring one in a nice dark red colour 112k fsh etc Ł7k??
cheers danny
Old Apr 10, 2010 | 08:09 PM
cutch's Avatar
cutch
Series 1 4x4 cossie
i just fixed mine, 53 plate, same model, as far as i know they all have the swirl flap problem that leads to destroying the turbo right up until the new shape on an 06???
heres the thread that deals with mine.
https://passionford.com/forum/genera...-fixed-it.html
As soon as you buy yours take the swirl flaps out and replace them with blanks, will give you so much more peice of mind.
Old Apr 10, 2010 | 09:35 PM
kiddie's Avatar
kiddie
Thankyou Cutch I'm now going to have a read mate, B19 cheers mate but we really like the one we've seen.
Cheers lads
Old Apr 11, 2010 | 07:39 AM
D11AKS's Avatar
D11AKS
my wife had a 320d sport 04 plate turbo shat its self due to the pre filter never been changed on the bloody thing
had full bm history done 70k and the filter wasn't part of the service these shpild be changed every 35k apperantly
Ł1200 for the repair
Old Apr 11, 2010 | 08:35 AM
Graceland's Avatar
Graceland
Team HOTHOT!
Pre filter? You mean the PCV Crank Case breather filter? If so, the old cottom type must be replaced at every inspection (as you say, never gets done) and this blocks and causes crankcase pressure and eventually turbo failure. However, BMW have re-designed the little filter and made a new one that is lifetime service free and works on a vortex type system that uses airflow to seperate the oil in the breather system instead of the cotton filter - Only about Ł35 and well worth changing!
Old Apr 11, 2010 | 09:03 AM
dave cos4x4's Avatar
dave cos4x4
i have not long got an 06 model, is it the same with these newer shaper cars or have they got round to sorting it out.
not seen anything in the service history.
Old Apr 11, 2010 | 09:06 AM
Graceland's Avatar
Graceland
Team HOTHOT!
newer ones had a re-designed all plastic swirl flap so if it breaks up it won't damage the engine Dave
Old Apr 11, 2010 | 09:07 AM
Jasesapphy's Avatar
Jasesapphy
if you can go for A 330D, I just brought a 330 and was going to buy 320d, i now know it would have been a mistake
I only had the 33od for days and it already felt slow, I got it remapped and its a lot quicker but even i still think it could do with more, its running 245bhp & 401ft lb
Dont get me wrong there great cars and fantstaic for what i do, (40K + a year), and do return between 39mpg & 55mpg depending on the mood
Old Apr 11, 2010 | 09:10 AM
dave cos4x4
thanks Paul.
Old Apr 11, 2010 | 01:32 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
I recently bought my 2004 320cd M Sport. Its a lovely car, can't fault it.
Turbos are better on the '04s due to them being an uprated design (with electrical wastegate actuator). So it was really only upto 53 you need to worry about turbos. However change the crankcase breather to a vortex one just incase .
Also, delete the swirl flaps, these are the only other major issue with the engine, blanks can be bought for Ł6/ea (you need four) and about 3hrs to remove the swirl flaps, fit the blanks, replace the breather and clean the EGR valve
Old Apr 11, 2010 | 01:51 PM
kiddie's Avatar
kiddie
Thankyou, been some great advice.
Cheers for all the replies
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
Oranoco
12
Oct 2, 2015 02:18 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Kam B
Sep 24, 2015 10:40 AM
roomey
Sep 19, 2015 08:40 AM
