3dr Rear brakes
Desperately need to upgrade my rear brakes from standard items
The front will be fitted with 325mm Brembo set up so what would work perfect with the fronts?
Are 4x4 calipers and bigger d+g discs any different?
i did put that on me rear but took erm straight of as didnt like them got the disc bells and callioer mounts if you after them !
http://www.compbrake.co.uk/BRAKEKITS...FORD_REAR.html
used once Ł350 ow much would you pay ! as new
And what is the difference between the 2wd and 4wd calipers??
Chris,I know Big Dave changed from standard to 4wd rear set up on my car and he said there was a big difference and much improved over the standard 2wd set up.I hope this helps.
Many thanks.Lee.
Many thanks.Lee.
4wd caliper clamps onto a vented disc
so you get a 2wd car with a 10mm wide disc 4wd clamps a 20mm wide disc
you need the brackets and alipers to go vented, but seeing as the hubs for the 2 and 4wd cars are the same, it's a direct bolt on replacement fix
the difference from 2wd and 4wd is on the disc, 4wd have same size as 2wd but ventilated, so the 4wd caliper is a little wider to fit over the disc. I would go gor this:
http://www.hispecbrake.co.uk/sierra_2wd.htm
I changed the rears on my 3 Door to 4x4 didn't really notice any massive stopping difference as I already had 6 pot 355mm on the front but I used to cook the 2wd rears could get the calipers to glow red!!!
But now with the 4x4 setup much better and no more cook brakes.
Rich
Rich
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
