Engine won't run at full power
Old Apr 10, 2010 | 12:17 AM
sonmic's Avatar
sonmic
Unhappy Engine won't run at full power
Hi again people!
My escort won't run over 3500rpm it just begins to cough, and won't give the proper effect, the turbo kick isn't there. I'm charing 1bar good tuned engine, whT cloud be wrong?
Thanks
- Sondre
Old Apr 10, 2010 | 12:18 AM
sonmic's Avatar
sonmic
It's the MFi system
Old Apr 10, 2010 | 12:28 AM
Chopshop85's Avatar
Chopshop85
Define good tuned engine?
List the modifications the engine has and when it was last set up.
Car coughing at 3500 is a bit vague. Is the turbo spooling at all? as I would have thought you would get a hint around 2000rpm.
Old Apr 10, 2010 | 12:43 AM
lurch1977's Avatar
lurch1977
Could be actuator
Old Apr 10, 2010 | 07:31 AM
sonmic's Avatar
sonmic
Originally Posted by lurch1977
Could be actuator
The actuator was new last year a -31 garret. The turbo spools fine it's a bigger turbo thou so lag started at 2500 before. Ok, i'll try my best to transalate the tuning.
- low comp oversized piston
- a mild cam doble valve spring
- stage 3 head
- balanced crank
- steinless steal exhaust
- kn conefilter
- stronger rods
- std. Exhaust side turbo with ar.42 with a 60 turbin cold side all of it ported.
- exhaust manifoil and innlet is portet
thats about it.
Old Apr 10, 2010 | 09:45 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Had a lot of this on here recently...
If things like plugs, leads, dizzy cap, etc.. are all good then sounds like underfuelling... again!
But could also be actuator, faulty sensor or ECU, etc.. lol
Old Apr 10, 2010 | 10:35 AM
sonmic's Avatar
sonmic
well if it was u der fueling it sound more "eletrical" than that "blarf" sound it has. This so typical my luck :P
Old Apr 13, 2010 | 06:21 PM
sonmic's Avatar
sonmic
also! my cold valve does not work anymore, could it be the ecu then?
Neatrags
Aug 16, 2015 07:57 PM
track.focus'd
Aug 12, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
ray barker
Aug 7, 2015 09:00 AM
Old ford
Jul 31, 2015 06:50 AM
