wanted coil pack wiring diagram for L8
as above still useing the phase sensor for now and is it the early or late coil pack and what do you do with the ht leads
cheers mate ive seen that one but it looked so easy the only hard bit is getting the ecu driver done and what about the leads there are two types of coil packs
its far from easy this conversion with L8 , the only person i know who can do it (or supply the parts for ) is simon from secs , speak to him !!
dont believe everything you read , be warned !!
155lee
Aug 14, 2015 11:21 AM
