clutch cable adjustment?
Old Apr 8, 2010 | 06:19 PM
liamford's Avatar
liamford
Default clutch cable adjustment?
hi guys, i have a problem with selecting a gear sometimes, its real hard to push in to gear...only sometimes tho, the clutch was changed about 5000 miles ago, if you push the pedal all the way down and select a gear, you hardly have to lift your foot and it starts to bite, could it be that the cable has stretched? is the an adjustment or would i need to buy a new cable?
its on a 96 st escos thanks
Old Apr 8, 2010 | 06:48 PM
grcossie's Avatar
grcossie
It`s a self adjuster under the pedal, this is made of plastic, and the theeth can get worn. Sometime it helps, to lift the pedal, and pull the plastic half moone down, then you push the pedal a few times. If you hear some click, then it has adjust a bit
Old Apr 8, 2010 | 07:11 PM
liamford's Avatar
liamford
ill give a try cheers, if it doesnt work im lloking at a new cable is it?
Old Apr 8, 2010 | 07:18 PM
grcossie's Avatar
grcossie
It could be, but check that the self adjuster dosen`t have worn theeths. It`s a shit place to work under the pedals
Old Apr 13, 2010 | 12:29 AM
liamford's Avatar
liamford
yeah that did the trick, but i think it may have worn teeth because it slipped back to the way it was earlier today , try and get new adjuster cheers buddy
Old Apr 13, 2010 | 05:39 AM
grcossie's Avatar
grcossie
Thats great, a new one and then you are sure, not so expencive.
Cheers mate
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Fezman1
Oct 2, 2015 01:22 PM
muz
Sep 30, 2015 08:29 AM
