OZ Cnunts
Old Jan 12, 2005 | 02:55 PM
Rick's Avatar
Rick
Default OZ Cnunts
Have discontinued alloys in Ford fitment, ie ET 37. They only do ET 42,43 for modern fords, ie focus etc.
Old Jan 12, 2005 | 03:05 PM
wildheart's Avatar
wildheart
Bastards i wanted a 2nd set soon
Old Jan 12, 2005 | 03:10 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Thats not the end of the world. Use a proper spacer set and get them spot on. To be honest, ET38 would be better for the rear anyway, so go for ET42 and 5mm Spacers.
Old Jan 12, 2005 | 03:58 PM
Rick's Avatar
Rick
are spacers safe/ effect the handling?
Old Jan 12, 2005 | 04:08 PM
mattbibs's Avatar
mattbibs
a proper spacer set should be fine. i bought 15mm ones off cossymad and never had a problem!
Old Jan 12, 2005 | 04:32 PM
S1MAN's Avatar
S1MAN
Ric
Dan's been tryin to call you but the number you gave don't work.
He says he's tried but he can't get the wheel you're after.
Colin.
Old Jan 12, 2005 | 05:15 PM
nthorpey's Avatar
nthorpey
Actuator in post yet ?????
Old Jan 12, 2005 | 05:22 PM
Rick's Avatar
Rick
Nick, ive pm's u twice? Once fri, once mon? Will try again.
Old Jan 12, 2005 | 05:52 PM
Christian and Beccy
#1 in Spelling Club
Rick, spacers are fine. I run 5mm Eibach Spacers. They are top notch.
Proper machined hub fitting.
Old Jan 12, 2005 | 05:54 PM
NUTS RuS's Avatar
NUTS RuS
Ford fit them as standard to the racing Pumas
Old Jan 12, 2005 | 06:21 PM
Rick's Avatar
Rick
Right then, where i get proper spacers from?
Old Jan 12, 2005 | 06:54 PM
Christian and Beccy
#1 in Spelling Club
Me.
