fuel pump
Old Apr 8, 2010 | 05:40 PM
mk1trb's Avatar
mk1trb
Boost Junkie
Default fuel pump
anyone know the correct part number for a rs turbo fuel pump? i can find 3 diff ones on ebay but some are 5 bar and some are 6 bar, which one?
Old Apr 8, 2010 | 11:14 PM
tasos77's Avatar
tasos77
rs turbo from Greece...
0580254910 is your number....
Old Apr 8, 2010 | 11:28 PM
mk1trb's Avatar
mk1trb
Boost Junkie
Old Apr 8, 2010 | 11:45 PM
tasos77's Avatar
tasos77
also you can use a sierra 2wd cosworth pump. i use one of them and i'm very satisfied! the 2wd part number is the same with -941 at the end..
Old Apr 9, 2010 | 03:59 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
910 is the rs turbo pump, 941 is the 2wd cossie one and better performance, there is of course the 979 which is better again then the 044 one, the last two need fittings for them to fit directly and wires altering for the connectors.
the latter two are good for at least 500bhp or there abouts though, so probably overkill.
Old Apr 9, 2010 | 07:49 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
RSt's run 6 bar system pressure
Old Apr 9, 2010 | 08:20 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah which is plenty for any 1.6CVH, when you consider that a FRST runs 3bar and a Cossie runs 3.5bar!
Old Apr 10, 2010 | 12:06 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
it's not only pressure but flow too, if you can run more pressure down th eline, then you will get more volume per second out the end, i.e. the injectors as the pressure can and will drop further down the line.
some of the better 044 pumps can give out 8BAR, even though injectors don't tend to run more than 3-3.5 BAR.
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
tib2220
Sep 14, 2015 12:33 PM
