mk1 xr4i boa conversion (help needed)
Old Apr 7, 2010 | 06:37 PM
cosworth220's Avatar
cosworth220
Default mk1 xr4i boa conversion (help needed)
hi guys, been doing alot to the car now and need some help.
could someone please tell me the which 7 pin relay i need on the loom?
and the part number on it if possible? i've been told that it's the same as on the granada for the fuel injection pump? but when i went to vospers the f&^*^ tw@t behind the counter said i needed the part number even when i gave him a granada boa reg!!
and also where do all the vacum hoses go????
i have no idea, ive noticed one off the back of the plenum and two off the throttle body.
and where does the one off the servo now go??
any help would be great
thanks
josh
Old Apr 7, 2010 | 08:20 PM
The Crocodile Hunter's Avatar
Hello mate, can't help you with too much of that but i assume you will have to drill and tap for the vaccum to the servo as the granada must have had abs which like a sierra with abs has no servo
Sure i'll be corrected if wrong
joe1979
Aug 26, 2015 05:08 PM
saph in dorset
Aug 14, 2015 10:10 AM
col93saphcos
Aug 7, 2015 03:21 PM
