fueling problems
Old Apr 7, 2010 | 06:06 PM
mk1trb's Avatar
mk1trb
Boost Junkie
Default fueling problems
right my xr2 turbo, mfi set up was running sweet monday but tuesday decided to cough and bang on boost, well under any load at all, fitted new plugs, leads, dizzy, cap and arm, coil, tps, act sensor, checked for air leaks nothing, it stinks of fuel from the exhaust and plugs are black but i can adjust the idle fueling but still does the same under load, think its basically overfuelling on idle then massivley under fueling under load. My only things to change are injectors and metering head so any ideas before i go get any bits
Old Apr 10, 2010 | 06:21 AM
Turbo Al's Avatar
Turbo Al
let me know how you get on, i have the same with my s1. replaced everything bar the injectors now. i dont know what like it is on the road as its on stands. misses and splutters when trying to rev her....doin my head in
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
15
Oct 7, 2015 03:43 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
RSBryden
Sep 6, 2015 08:39 PM
