Coilover squeaks?
Old Apr 7, 2010 | 02:12 PM
Ima Racing's Avatar
Ima Racing
Default Coilover squeaks?
Will review car later but there is a horrible squeak creak coming from both sides at rear push rear up down and loud lol what is it coilovers these are new and gaz golds???? How do i stop it
Old Apr 7, 2010 | 02:21 PM
Its Dave's Avatar
Its Dave
Don't drive it could help
Old Apr 7, 2010 | 02:22 PM
lead_foot's Avatar
lead_foot
is awesome
Stop pushing the rear up and down.
Turn up the tunes or wear some ear plugs.
Old Apr 7, 2010 | 02:39 PM
Ima Racing's Avatar
Ima Racing
Good job i posted up on escos site i may get a mature reply lol
Old Apr 7, 2010 | 02:45 PM
Char1ie's Avatar
Char1ie
Gaz Gold on a Sapph? The springs rub on the inside of the turrets. Drive it for a while, then you'll see where they have rubbed, then take a hammer to the turret to give some clearance.
Charlie
Old Apr 7, 2010 | 02:49 PM
NoRubNoDub's Avatar
NoRubNoDub
McGarrity Motorsport
Sounds like you have ruddy mice again?
Old Apr 7, 2010 | 02:50 PM
Ryan's Avatar
Ryan
easy solution is sell the coilovers.
and fit koni's
Old Apr 7, 2010 | 02:55 PM
Ima Racing's Avatar
Ima Racing
Why ryan these are great and its obviously got the correct springs fitted as its fairly comfortable.
Of course just realised it must be rubbing i had this before with the ohlins on the escos out comes that hammer will check first though before hammering lol
Old Apr 7, 2010 | 02:57 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
Phil my 3dr gaz coilovers did the same. Matt was too lazy to ever sort it () but it drove me insane. In my wisdom i removed them and fitted my brand new konis. WORST thing i ever did as the car drove better on coilovers with the 8" wide wheels
Anyway just bash your rear a bit.
Old Apr 7, 2010 | 03:02 PM
Ima Racing's Avatar
Ima Racing
Cheers chops its very annoying lol this feels great on these coilovers better than any other cossie i had, the escos had std gaz coilovers and was very hard this feels great
Old Apr 7, 2010 | 04:26 PM
markk's Avatar
markk
have offset spacers made if they have rose jointed bottoms - but then again they are cheap coil overs so you might just have bushes.
Old Apr 7, 2010 | 04:44 PM
charlie luciano's Avatar
charlie luciano
Coilovers are noisey/creaky paticularly on the n/s rear, on fitting the n/s rear inner wing requires a bit of attention with a hammer
make sure springs are sat properly in their cups if they are not it will creak like a poofs leather trousers
Luciano
Old Apr 7, 2010 | 06:07 PM
Toe Knee's Avatar
Toe Knee
funny u should say that ive had the same thing with my avo's on the n/s rear too!! bashed the inner twice now with a hammer and its not as bad but still sounds like its catching!!! Guess im gonna have to take it off again and have another loo
Old Apr 7, 2010 | 06:17 PM
Ima Racing's Avatar
Ima Racing
Luciano
Cheers, i think they might not be seated right them springs as thinking it sound more like that than actual rubbing.
Old Apr 7, 2010 | 06:23 PM
cossiejay's Avatar
cossiejay
turn the stereo up this is what i do in our squeaky golf
Old Apr 7, 2010 | 06:55 PM
gibbo frst's Avatar
gibbo frst
ive got gaz golds on mine and they dont rub or creak.. mine has the rose joints and on the bottoms they are different sizes so i put the bigger spacer on the inside to push it away from the inner arch on either side if that makes sense.. have a look at the bottom mount and see if they can be moved..
Old Apr 7, 2010 | 08:05 PM
fordrallycar's Avatar
fordrallycar
I Had this problem on my gaz golds the cure was WD40 give them a good covering that should help
Old Apr 7, 2010 | 08:21 PM
Ima Racing's Avatar
Ima Racing
Really? Will try that too...cheers folk
Old Apr 7, 2010 | 09:19 PM
WongRS's Avatar
WongRS
My avo's did this, it was the springs rubbing in the turrets, a couple of minutes with a hammer sorted it
Old Apr 7, 2010 | 09:59 PM
Paul_RS's Avatar
Paul_RS
My Mag Bilsteins have those, no rubbing at all on my car
Old Apr 7, 2010 | 10:18 PM
BRAMMER's Avatar
BRAMMER
Charlie
Exactly what i had with my non gold
jessie_rs
62
Aug 6, 2019 09:27 PM
mk1turboestate
Dec 2, 2015 08:31 PM
S3an
Sep 26, 2015 11:39 PM
CrOwSoN15
Sep 24, 2015 01:36 PM
S3an
13
Sep 13, 2015 10:01 AM
