Silicone hose v brake fluid
Old Apr 7, 2010 | 11:50 AM
cj_rst's Avatar
cj_rst
S2 RST
Default Silicone hose v brake fluid
I've just removed my ABS but still have the original reservoir. I found a bit of silicone hose in my toolbox the perfect length to block off the outlets, but what I need to know is whether the bit of hose will be up to the job as a temporary fix before getting a non-ABS reservoir? Is the brake fluid going to attack the hose and make it leak? Any help appreciated
Pic of what I mean, just in case, - you can see the U shape hose on the reservoir:
Old Apr 7, 2010 | 12:13 PM
Karlos G's Avatar
Karlos G
Balls Deep!
If it's Fluro lined then should be ok (not 100% though), like a fuel line or oil line is, otherwise no!
Old Apr 7, 2010 | 03:29 PM
cj_rst's Avatar
cj_rst
S2 RST
No it's not lined, and I thought the same as you... hmm what to use
Old Apr 7, 2010 | 06:32 PM
wayne dowling's Avatar
wayne dowling
try an old brake flexi hose cut to size
Old Apr 7, 2010 | 09:47 PM
cj_rst's Avatar
cj_rst
S2 RST
GENIUS! Fook me I feel stupid sometimes Could've thought about that one really couldn't I
I've got a spare brake hose in the garage somewhere, cheers mate!
Nov 1, 2015 06:53 PM
