What year do...........
Old Apr 7, 2010 | 08:11 AM
Ima Racing's Avatar
Ima Racing
Default What year do...........
...cars need the cat for the MOT?
Old Apr 7, 2010 | 08:13 AM
Jay246's Avatar
Jay246
1993/4 for petrol iirc.... diesels dont
Old Apr 7, 2010 | 08:27 AM
turbotoaster's Avatar
turbotoaster
i think 92/J reg is the last year you cannot have one, for imports your allowed up until 1995
Old Apr 7, 2010 | 08:33 AM
Ima Racing's Avatar
Ima Racing
...so we have a difference of opinion?...i had an inkling it was 94
Old Apr 7, 2010 | 08:34 AM
It's Czech Mate's Avatar
It's Czech Mate
No car needs a cat to pass an MOT
All they need to do is pass the relevant emmisions test
Old Apr 7, 2010 | 08:35 AM
Stoo's Avatar
Stoo
Edit. There you go ^
Old Apr 7, 2010 | 08:37 AM
Ima Racing's Avatar
Ima Racing
...so a k reg sapphire will be 3.5% ?
Old Apr 7, 2010 | 08:39 AM
Twellsie's Avatar
Twellsie
my k reg saff didnt have a cat and i never had any problems getting it through an MOT
kjc300's Avatar
kjc300
After sept 1992 iirc all uk petrol cars had to be fitted with a cat. Doesn't mean it needs one though, but it does have to pass the 'cat standard'.
Old Apr 7, 2010 | 08:42 AM
rog's Avatar
rog
As above, exactly correct as far as I'm concerned.
Old Apr 7, 2010 | 08:45 AM
RichieST's Avatar
RichieST
Although you don't technically need a cat to pass an MOT, if you are pulled in by VOSA for one of their roadside stops, they will do you if you've removed the cat! Happened to a friend of mine. Not worth the bother IMO.
Old Apr 7, 2010 | 08:53 AM
rog's Avatar
rog
Don't think that's possible???
How you they prove you removed it if you haven't had the car from new?
If the physical presence of a cat is not checked at an MOT then how would it stand up in court? It's perfectly possible for the car to pass it's emissions test without a cat installed.
Old Apr 7, 2010 | 08:58 AM
RichieST's Avatar
RichieST
I don't know mate to be honest.
Probably the same way that an old car of mine passed the MOT with tinted windows, yet I got pulled in for a VOSA check and got done for it.
Old Apr 7, 2010 | 09:09 AM
jaiscossie's Avatar
jaiscossie
Its 1992 as said above as many moons ago i had a 92 reg xr4x4 sierra and it had no cat and just got through because of the month it was built or registered.Not sure which off hand now.
carlo's Avatar
carlo
Phil was it not only the green top cossies that came with the lambda sensor ect? if yours is a red top it should be ok? i could be totally wrong but that was my understanding
Old Apr 7, 2010 | 09:12 AM
rog's Avatar
rog
I'm sure its 1st August 1992, mine is a greentop and I've fallen foul of this a few times so I'm changing back to closed loop to help things out in that dept.
Old Apr 7, 2010 | 09:22 AM
KSA-Cossie's Avatar
KSA-Cossie
Mine too,good old MSD closed loop.
cossiejay's Avatar
cossiejay
+1 if you can get it through the emmisions with out it ,it dont need one
Old Apr 7, 2010 | 10:41 AM
Twellsie's Avatar
Twellsie
mine wasnt on closed loop
Old Apr 7, 2010 | 11:38 AM
Ima Racing's Avatar
Ima Racing
This car is closed loop so no worries then
Old Apr 7, 2010 | 01:43 PM
I do 0.97% CO, 137PPM, on GREYS/T34, with very close on 190,000 miles on bottom end, NO CAT in sight,
NO CLOSED LOOP in sight, but then it is mapped correctly.
Old Apr 7, 2010 | 01:49 PM
Stu @ M Developments's Avatar
PassionFords Creator
Originally Posted by tabetha
I do 0.97% CO
So you would fail the catalyst test. How is that of interest to this topic?
Old Apr 7, 2010 | 03:01 PM
iansoutham's Avatar
iansoutham
OCD Victim
Legal limit for a cat-test is 0.3% CO.
Old Apr 7, 2010 | 03:05 PM
jonny s2's Avatar
jonny s2
Old Apr 7, 2010 | 04:23 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
worst case rebuild it with a pre 1992 block and use the engine age to get round emissions regulations not the cheapest method though
TPM961
Jan 15, 2018 10:50 AM
Shows & Track Days
Apr 27, 2016 11:04 AM
nico12
Dec 31, 2015 04:42 PM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
