Randoms + Tool Kit + Boost pipes.
Almost there!
Escos Tool Kit, complete with everything, in the foam assembly and with the carpet that goes over it - £100
ST inlet throttle assembly with ISCV - £40
Black Roose boost pipe, from intercooler to inlet manifold. to suit intercoolers with the larger diameter pipes - £25
Pair of standard rear calipers, very dirty and grubby and been sat redundant in the garage for a few years, but were working perfectly when removed from my car 3 years ago - £25
ive found a set of Cossie Yellow injectors. £20
Passenger kick sill, the long plastic section that runs the length of the door and up to the underside of the dash. £4
full set of standard shocks, this does include fronts and rears. £20
removed from my car aprox 4 years ago when changing to coilovers (stupidly i binned the springs when we moved)
a pair of 4x4 manifolds, both have the usual tiny hairline cracks within the webbing, but obviously doesnt effect its use - £10 each
Cassette tray, from within the armrest centre consul of the escos, if its of any use to anyone :dunno:
£4
£4
Russ Payne
Sep 25, 2015 08:29 PM
