Leak on inlet pipe before turbo
Old Apr 6, 2010 | 05:19 PM
andre_k's Avatar
andre_k
Default Leak on inlet pipe before turbo
ive just noticed a 1cm tear in the inlet pipe, just before the turbo. its after the maf sensor.
would this cause the car to lose power?
Old Apr 6, 2010 | 06:13 PM
RichieST's Avatar
RichieST
Yes, because you will be sucking in air through that split, and the MAF will not be measuring that air. So there's more air in the system than the ECU thinks there is, so it will run lean.
big_Rad
Sep 15, 2017 09:36 AM
Danielbetty
Oct 3, 2015 06:01 PM
Matt Baxter
Sep 16, 2015 08:30 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
mattman1234
24
Aug 1, 2015 11:46 AM
