cosworth engine bits ALL SOLD
Old Apr 6, 2010 | 04:47 PM
cossytonyt's Avatar
cossytonyt
Default cosworth engine bits ALL SOLD
bought this lot as a project was going to rebuild and keep as a spare,the engine was running fine with no knocks or rattles but was smoking,new turbo was added but still smoked it was stripped for inspection and was found to be the block (overbored) and slightly ovaled.still have the block as still has nearly new oil pump/water pump etc still fitted,also 2 sets of pistons standard with rods and arp bolts and a set of accrelites the accrelites where in a high spec engine and only done approx 50 miles before spec was changed they were originally supplied by mountune,
basically everything is there apart from an exhaust manifold and turbo
ie
complete head with camcover etc as removed
block with near new oil/water pump etc
2wd sump
pick up pipe
dizzy
crank was no knocks but is marked so would get checked still has the shells fitted etc
2 sets pistons standard with rods and arp bolts plus set of accrelites
complete inlet manifold plus a freshly refurbed powdercoated one
and any other bits i can find that ive forgotten that go with it
due to weight pick up only from sunderland tyne and wear £650 ono
a few pics will sort some more
Old Apr 6, 2010 | 05:38 PM
COCHYN's Avatar
COCHYN
How bad was the smoking and when did it happen, on overrun, throttle? Just curious
Old Apr 7, 2010 | 08:24 AM
R4N SS's Avatar
R4N SS
are you open to offers on this as its a bit far from me?
Old Apr 7, 2010 | 09:49 AM
Joe Grp4 Escort's Avatar
Joe Grp4 Escort
Interested in a few bits if you decide to split Tony
Old Apr 8, 2010 | 09:46 PM
cossytonyt's Avatar
cossytonyt
sorry for delay in answering been busy think it smoked on accel and overrun will check with the garage that inspected and changed the engine.
would rather it all went together but you can pm me offers on any individual parts
will get prices on courier/pallet costs
Old Apr 9, 2010 | 05:34 AM
big ord's Avatar
big ord
what size and comp are the pistons do there have valve cut outs and if only dun 50 miles the rings will be as new as well
cheers
Old Apr 9, 2010 | 11:58 AM
R4N SS's Avatar
R4N SS
im interested in the lot as want to build a complete engine - what block is it 205 or 200?
Old Apr 9, 2010 | 08:44 PM
cossytonyt's Avatar
cossytonyt
cheers
havent got valve cut outs phil waiting for some specs
205 block which is apparently no good
Old Apr 10, 2010 | 06:11 PM
Captain500rs's Avatar
Captain500rs
Should of gone to specsavers
Old Apr 10, 2010 | 06:32 PM
cossytonyt's Avatar
cossytonyt
SOLD.............................................. ...............................
big_Rad
Sep 15, 2017 09:36 AM
carlo
24
Oct 5, 2015 08:20 PM
Bart
Aug 9, 2015 09:04 AM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
