Best TPS for Autronic
Old Apr 6, 2010 | 12:29 PM
ozmk1cos's Avatar
ozmk1cos
Default Best TPS for Autronic
What is the best tps for autronic smc. I have a pf01 and pf09 but in the manual its says
1. Throttle is fully closed the output voltage MUST be in the range 0.4 volts to 1.8 Volts.
2. Throttle fully open the output voltage MUST be in the range 3.2 to 4.7 volts.
and as far as Im aware both cossie sensors work between 0-5 volts.
Whats my options.
Old Apr 6, 2010 | 02:04 PM
oldford's Avatar
oldford
Change for a Bosch one that is linear wit a 3K to 20K Ohm total resistance.
PF01 will produce 0.0 or 5.0 volts at idle, depending how you connect it.
PF09 will give around 0.2 volts at idle and around 4.75 volt at WOT.
Old Apr 7, 2010 | 01:19 PM
The voltage can only be between the output of the ecu and signal return.
Most universal tps I've used are around the 50K ohms mark, but data with ecu should tell you precisely what you need, but irrespective of that surely it can just scale between idle and fully open anyway ?
Old Apr 7, 2010 | 01:31 PM
ozmk1cos's Avatar
ozmk1cos
Cheers fellas. Im going to put on the pf01 as I have found a couple of people using them with out hassle.
DixieTheKid
11
Jun 6, 2020 11:20 AM
15
Oct 7, 2015 03:43 PM
muffster
13
Sep 3, 2015 09:40 PM
cozzy jeff
Aug 31, 2015 04:14 PM
Roosie
Aug 15, 2015 08:09 PM
