Cosworth boost problem,
Old Apr 3, 2010 | 02:36 PM
studabear's Avatar
studabear
check all hoses etc, esp map sensor
Old Apr 3, 2010 | 06:49 PM
Could well be DV, remove and plug hole to check, a broom handle is ideal size, not the whole handle though!!
Old Apr 3, 2010 | 07:57 PM
martysmartie's Avatar
martysmartie
Sounds promising, it's probably a deteriated plug rather than a dead one of you will notice it more, will show more on boost, depending how bad it is you can always clean the earth electrode in the mean time, not convinced this is causing hunting issue though.
Martin
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
jay030787
Aug 17, 2015 06:16 PM
Aug 14, 2015 07:29 AM
Escortdriver1
Jul 31, 2015 02:36 PM
