escossie stereos problem
Old Apr 3, 2010 | 10:17 AM
YBT200's Avatar
YBT200
Default escossie stereos problem
hi, i have the original stereo and cd player of an escort cosworth an they where working well when all of a sudden they stopped with no power, fuses are all good. anyone knows what could it be ?
Old Apr 5, 2010 | 01:58 PM
YBT200's Avatar
YBT200
any help pls!!!!!
Old Apr 5, 2010 | 06:12 PM
grcossie's Avatar
grcossie
Do you have power in the stick behind stereo??
Old Apr 6, 2010 | 04:45 PM
YBT200's Avatar
YBT200
i will check. if there is power what could it be the stereo i think?
Old Apr 6, 2010 | 06:08 PM
grcossie's Avatar
grcossie
If you have power and earth there, then it must be stereo. Remember that it should be 2 pins whit power, one for memory ho is always on, and one ho is conected to key in position 1, that switch your stereo on
Cheers Geir Rune
Old Apr 6, 2010 | 08:54 PM
martysmartie's Avatar
martysmartie
As said you need two lives for the radio to work (Constant and Switched Live) if you have these along with a good earth theres no reason why it won't work unless radio itself has broken.
Martin
DAZZER
Sep 30, 2015 08:43 PM
stevecfrst1
Sep 30, 2015 05:18 AM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
