2wd Oil pump base - how does it work?
Old Apr 2, 2010 | 10:52 PM
AndyPen's Avatar
AndyPen
Default 2wd Oil pump base - how does it work?
My new oil pump came without the base and I've noticed a few in pics on here that are similar... so I use my old one I guess.
Following advice here I've had it lapped a little to reduced scoring and noticed when cleaning it that oil doesn't run straight into the hole in the base and come out of the hole that feeds the spray rail - should it?
Could it be blocked or is there some kind of valve in there?
Bit confused by this one and its essential to be sure before I refit it eh?
big_Rad
Sep 15, 2017 09:36 AM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
steerfromdarear
28
Jan 29, 2016 06:14 PM
Dubs44
Aug 21, 2015 02:42 PM
