I have one and it seems very good. Feels much more controlled at the back. Only thing i would say is that if you use a 22mm rear arb try and get some flush mount bolts to avoid knocking
I have an exact copy of this mcracing one, the diff support is a joke with the std bush, this makes a awsome difference, I didn't pay that though, there are cheaper out there.
how much was yours tabetha?
im looking to get one soon!
cheers shaun
just brough the above product as looked around and couldn't find any other ones other than the 2 others on ebay 1x a lot more expensive and another one about 15 pounds cheaper but cheap isn't always the best way to go, does any one no were i can get a set or one planet gear for my diff as i have a small chip about 2.5 mm on one tooth
