Nitrogen filled tyres..
WELL I DIDNT THINK IT WOULD MAKE THAT MUCH DIFFERENCE BUT ITS INCREDIBLE,YOU CAN FEEL THE DIFFERENCE STRAIGHT AWAY,HAD MINE DONE THIS MORNING SO SHOULD GET BETTER HANDLING,BETTER FUEL CONSUMPTION,BETTER TYRE WEAR AND MORE CASH IN THE POCKET..
http://uniflate.com/
By having your tyres at the correct pressures you will experience the following benefits:
1. Better handling and road holding
2. Reduces tread wear and increases tyre life by up to 25%
3. Correct inflation pressures reduce puncture risk by up to 33%
4. Reduced rolling resistance improves miles per gallon by 2%
5. Improved pressure retention
mmmm see what your saying but i think thats the whole point,it will save you having to do that every week plus you get no oxidation because no water or or oxygen meen no more corrosion of wheels,im well happy with it mate
Nitrogen is formed by distilling liquid air at -196C, Nitrogen also contains a few % noble(inert) gasses such as krypton, neon, argon, xenon.
The reason why nitrogen is used is it doesn't react to the heat produced by the tyres friction with the road, so maintains the pressure more accurately, ordinary "air" expands with heat, owing to the hydrogen content, a fact exploited by the germans with thier heavy water explosives, where H2O became 3H2O.
Obviously they will be better when cold or extremely hot than normal air filled tyres, but tyre temps remain fairly stable in use so if correctly inflated will be just as good.
Adding ULTRASEAL acts as a cooling agent, owing to its' high aqueous(water) content, it also stops 100% of punctures for holes up to 8mm, makes the tyres last around 30% longer, use this myself, a puncture fix is remove the screw nail etc and drive, is permanent cure, is totally non toxic, you can eat it, will make you sick but not ill, can be washed out with water, gives off no fumes.
It's got nowt to do with handling.
SMILER258
Sep 28, 2015 09:04 AM
