s2 paddle clutch sliping i think
Old Apr 2, 2010 | 04:43 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default s2 paddle clutch sliping i think
hi when go on high boost i get to 4k rpm and floor it my clutch slips, but if i gradually go up the rev range it doesnt slip, on low boost its fine on all driving styles.
is it time for a new clutch?
Old Apr 2, 2010 | 06:18 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
yep on its way out.
how much boost are you running and how many miles has it done?
even on 21psi of boost on my zvh mine doesn't slip, although not that old.
Old Apr 2, 2010 | 06:29 PM
conor.rst's Avatar
conor.rst
Just out of interest what happens when your clutch slips i have never had it before ?
Old Apr 2, 2010 | 06:30 PM
studabear's Avatar
studabear
engine revs car doesn't accelerate
as the clutch has lost its grip
Old Apr 2, 2010 | 06:37 PM
conor.rst's Avatar
conor.rst
dose what it says on the tin then cheers
Old Apr 2, 2010 | 10:25 PM
Karlos G's Avatar
Karlos G
Balls Deep!
On it's way out or just not rated to enough torque in the first place
Old Apr 3, 2010 | 10:05 AM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
running about 18psi on high boost, got helix 4 paddle with std clutch plate, only done about 12k on the clutch, is it hard to change the clutch yourself? so i can save money etc.
What would people recommend for holding about 200 bhp and the same in torque.
Old Apr 3, 2010 | 10:39 AM
muz's Avatar
muz
Wye Valley Hardcore
When my 4 paddle was on it's way out it juddered very badly in traffic also. Remember to have your flywheel re faced/skimmed before you fit the new clutch as well. You'd be supprised the amount of people who don't.
Old Apr 3, 2010 | 11:06 AM
crazycage's Avatar
crazycage
you have done very well to get 12k on it mate i never used to get more than half that. its time for a new one .
Old Apr 3, 2010 | 11:31 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah paddle clutches are not designed to last long, there is so little material specialy on the little 3 and 4 puck ones!
An AP Racing CP2000-8 will do perfectly for what you want and will last ages compared to any paddle
Easy enough to change, just need to drop the gearbox, little bit fiddly to get back but ok.
Old Apr 3, 2010 | 01:47 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
how about a organic clutch? ap? its not a everyday driver anyway.
Old Apr 3, 2010 | 01:53 PM
Karlos G's Avatar
Karlos G
Balls Deep!
The AP CP2000-8 is an Organic clutch mate!! lol
Old Apr 3, 2010 | 02:41 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
are the organic clutches easier to use then a 4 paddle, ie heavy pedal feel etc, what power will they take?
Old Apr 3, 2010 | 03:14 PM
Karlos G's Avatar
Karlos G
Balls Deep!
They do not judder like a paddle but the pedal feels heavier than a standard clutch yes.
The 8 is good for about 250ftlb IIRC, above that you fit a 35.
Old Apr 4, 2010 | 11:42 AM
anvini's Avatar
anvini
Hi Karlos
I was running with 7 psi boost (with standard engine spec) but after up boost to 12 psi (peaks up to 15 psi) my standard clutch is slipping ocassionally on 4 and 5th gear when I put my foot down the floor on accelerator.......
Do you recommend AP Racing Cp2000-8 for a daily car (occasionally fast running on weekends)??
Do you think Standard clutch will slip again after fit a new one?
I want to fit a clutch better that standard one, but I don´t want to fit a "oversized" clutch for my engine specs......
You said pedal feels heavier but how much heaver it feels, a little heavier???
Regards.
Old Apr 4, 2010 | 12:55 PM
Karlos G's Avatar
Karlos G
Balls Deep!
A standard RST running 12psi will make about 155bhp and similair torque so a standard clutch should be fine, I would say yours is worn out.
Or the AP CP2000-15 would be a good alternative, not as heavy as the 8 or 35 but will take a little more torque than a standard clutch
Old Apr 4, 2010 | 03:02 PM
anvini's Avatar
anvini
Yes, Maybe my old clutch is worn.....I don´t know how much mileage got it....
So no needed to make mk5 pedal conversion with AP CP2000-15, is it right??
Where can I buy AP CP2000-15 kit online??
I had check on Burtons but I didn´t see it on CVH engines.......
I´ll make search with reference part...............
Many thanks Karlos!!!!!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
