Inlet hose
I was having a poke around the back of the block on my project car and ive just noticed a hose id completely forgot about it comes off under the back of the inlet manifold it looks like it would go to the oil cooler but seeing as ive got a zetec bottom end ive not fitted it due to space issues so my question is can i just "T" this hose into the heater pipe work as i presume it needs to drain some where ?
Cheers mark.
Ps ive not had the engine running yet im still putting bits together in the bay hence why ive only just noticed this hose.
Cheers mark.
So the little hose that comes off the main hose from the rad to the water pump goes to sensor block on the left hand side of the inlet manifold then the hose that comes out the other side of the sensor block T's into the one out the bottom of the inlet manifold and goes to the heater matrix ?
Cheers mark.
Cheers mark.
Yeah its mfi
I know its abit vague saying the sensor thing but this will be my first rs engined car so im still learning what everythings called lol
Russ Payne
Sep 25, 2015 08:29 PM
