AE Map based or TPS?
Old Apr 1, 2010 | 05:13 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Default AE Map based or TPS?
I find it works better using map based rather than TPS, but when on boost because rapid fluctuation (rate of change) in MAP it comes on frequently so have not been using it.
What are other people experiences and preferences?
Cheers!
Old Apr 1, 2010 | 06:35 PM
Rick's Avatar
Rick
EAE
Old Apr 1, 2010 | 07:46 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i'm on tps, but i have a little noise/fluctuation on my tps so have to filter out the first 11%/s, so on light throttle, i don't get much enhancement. i tried a mix with map and it seems alright, but needs tweeking for sure.
i wanted to go onto Enhanced Acceleration Enrichment, but seemed too much to alter for my none existant experience.
Old Apr 1, 2010 | 09:37 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Originally Posted by Rick
EAE
Not looked at that, what advantages does it have?
Old Apr 1, 2010 | 10:46 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Ok just had a read of the EAE part of the 'Manual' and it looks pretty simple really, just small methodical adjustments until you get the response/AFR's you want!
Much much more accurate than Map vs TPS and will provide a much smoother result I would imagine.
Will have a play once my main VE table is finalised as without that beeing 100% it's a waste of time! lol
Have a look here xr2wishy http://www.msextra.com/doc/ms2extra/...anual.html#EAE explains it all really well!
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
SMILER258
Sep 28, 2015 09:04 AM
jay030787
Sep 25, 2015 01:38 AM
