Engine won't run properly.
Old Apr 1, 2010 | 02:18 PM
sonmic's Avatar
sonmic
Default Engine won't run properly.
Hi!
I have just changed my metering unit, and after start up, it sounds like the engine is choking. Could it be some of the sensors that are placed wrong or fuel lines. Thanks for any help i can get every tip is welcome!
Old Apr 1, 2010 | 02:32 PM
cossie j's Avatar
cossie j
if you just changed your metering unit you have to let it run for a 4/5 min's to bleed any air out the system it happened to me then ran ok but if that dont cure it check for air leaks and that you put the injecter pipes on the metering unit right
Old Apr 1, 2010 | 03:07 PM
sonmic's Avatar
sonmic
Will try this mate, thanks!
Do you also know where the injectors is supposed to be?
Old Apr 1, 2010 | 03:17 PM
cossie j's Avatar
cossie j
looking down at the merering unit/ top left is no3/ top right is no4 bottom left is no2/ bottom right is no1 .number 1 injecter being cam pulley side
Toe Knee
Aug 23, 2015 08:31 AM
Bailes1992
Aug 16, 2015 07:14 PM
track.focus'd
Aug 12, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
