Engine won't run properly.
Hi!
I have just changed my metering unit, and after start up, it sounds like the engine is choking. Could it be some of the sensors that are placed wrong or fuel lines. Thanks for any help i can get :) every tip is welcome! |
if you just changed your metering unit you have to let it run for a 4/5 min's to bleed any air out the system it happened to me then ran ok but if that dont cure it check for air leaks and that you put the injecter pipes on the metering unit right
Originally Posted by darkxre4per
(Post 4825864)
Do you also know where the injectors is supposed to be? |
looking down at the merering unit/ top left is no3/ top right is no4 bottom left is no2/ bottom right is no1 .number 1 injecter being cam pulley side
| All times are GMT. The time now is 01:46 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
